I have two 'runs' of radiators.
One run heats up quickly and nicely, all the radiators on the other run take quite a bit longer to heat up.
So I balanced the first run and have opened both valves on the radiators on the other run.
My logic behind it was that the hot water would take the path of least resistance and go and heat the open valve run first.
But to be honest it doesn't seem to have made that much difference.... maybe a bit. So... should I balance the radiators on this run as well?
Also... if I full opened all the valves on all the radiators what would be the implications of this?
Would the first radiator get scorching hot, the next one a bit cooler, etc etc until the last radiator in the run would be stone cold?
