I have recently replaced a window and as a result will have to drop the height of the internal window ledge. There is a radiator directly below the window ledge and when the ledge is dropped, the bottom of it will sit just 2 inches above the top of the radiator.
Is this likely to cause me any problems ? Will the heat from the radiator just be lost to the space behind the curtain ?
I could possibly lower the radiator a little if I had to - but this would take quite a lot of effort, so I don't want to without good reason.
Thanks for the replies !
