hi,
hope someone can help - one of my (trv-less) rads is driving me up the wall.....
i moved into this flat last Sep and discovered when the cold spell hit that one rad was stone cold. i've had British Gas round twice recently - the first time all the rads were bled and that got this bad rad working fine.... for a while. a few days later it went stone cold again. the BG engineer came back, said probably trapped air in pipes had got into rad, and bled it again (by opening one of the lower valves). less than a week later, it's turned back into a popsicle.
i've tried bleeding the rad from the bleed valve and water squirts out right away. also tried turning all other rads off then putting CH on. i've got a Maxol microturbo 40H boiler and this rather odd (to me) system where i can't get CH without turning HW on, and i believe a pressurised sealed system.
hope this question doesn't sound too dumb, but what could be wrong with my bad rad? and is there any way i can change the system so that i don't have to have HW constantly running to keep my flat heated?
all thoughts appreciated.
