Hello, i need to bleed a radiator at home, but the square bit that you put the bleed key onto has been worn away and now the bleed key wont grip it. Is there any other way to bleed it apart from trying to use pliers?
ok thanks. do i then have to add any more water or something? i think i have an open vented system, but not sure. as you can see i am a bit of a novice
how is undoing the nut on a lockshield going to help? the lockshield is at the bottom of the rad, the air is at the top. icon_rolleyes.gif icon_rolleyes.gif
