Radiator droning noise
31 Dec 2006
Staffordshire
Hi once again , and a happy new year to you all.
Got a problem with my rads.
Had a new combi boiler fitted around 13 months ago and all has appeared to be ok. Now I occasionally get a droning noise from one or two rads which is cured temporary by lowering the rad thermostat and back to its original setting.
On one of the rads, if you raise then lower you can hear a clunk from it.
I have bled the rads but no air seems present.
Thanks in advance for the help
Jase
you need new thermostatic rad valves
Probably the flow and return pipes were reveresed when the chap installed your combi and the TRV's you have are not the bi direction types that are used these days
Not a big deal
they were installed at the same time as the new boiler, although I remember him one time taking the valve off and gently tapping the pin. But I cant seem to get them off!
Are they twist or pull off generally?
Most new ones have a knurled ring at the bottom of the numbered head that has to be undone first.
mmm
thats rum
I would be tempted to get the changed under warrantee if I were you as they shouldnt be humming
Will have a go myself as if it is just that the pin needs releaseing, then it should not be a problem doing it myself.
If not then I am lucky enough that the guy lives close by but he is very unreliable for further jobs I have asked him to do!
Well if then pins do need releasing AGAIN then the valves aint much cop are they
Just be careful and dont flood yourself
Thanks a lot. Will give it a try on an easy to get at one first!
Will be gentle to the pin. Thanks for the advice as always
