Radiator extension valve
23 Aug 2013
South
Hello, despite my house be built in 2000, all the radiators are imperial.
I found some rigid extenders on Toolstation but has some bad reviews and someone said “it kept splitting so bought from a plumbers merchant in the end”
I understand they couldn’t say where, but can you recommend good quality ones?
And just so i’m on the right tracks, one of the radiators is 720mm, so i’d buy a 700mm metric radiator and two 10mm rigid extensions
And another radiator is 480mm, so buy 400mm and two 40mm rigid extensions or 500mm and two 10mms? Getting confused here now
All my pipe work for the radiators come out of the wall instead off the floor, so I think extensions would be easier and look better than having right angles for the pipe work.
