The fixing have come out of the plasterboard and the radiator has come off the wall causing one of the copper pipes to leak slightly. The pipe is on the opposite side to the regulator valve. A bit of advise would be very much appreciated.
A For Sale board might do the trick though
In which case knock down the whole council and rebuild them!!so the local council might be a bit miffed.
A For Sale board might do the trick though.
Unfortunately, I'd say you'd need to take the rad off the wall and refix the brackets. Obviously you're going to have a hole in the wall now where the original fixing has come loose. Most brackets have multiple holes for fixings so just use one that's higher or lower.
Refix using something like these (theyve never let me down)
http://www.screwfix.com/prods/11923?cm_sp=AOVDriver-_-Fixings-_-MetalRediDrivas&ts=53555.
Also as the weight of the rad is now resting on the lockshield valve (the one that's leaking), when you drain down it might be worth having a look at the condition of the pipe as it maybe have bent / cracked.
Cheers
