radiator fitting in conservatory
1 Feb 2004
im having a rad fitted in my conservatory and would like to know if it can be taken straight from the combi (worster 240) can a trv be fitted as no other rads are fitted with them. can't connect from another rad as pipe size to rads are 10mm and to many obstuction in the way. rad is to fitted to oppisite side of wall to the combi
thanks
I should think you can connect as you ask, you need to make sure the lockshield valve is only open about 1/4 too 1/2 turn, otherwise your other rads wont get hot.
