- Joined
- 17 Oct 2005
- Messages
- 22
- Reaction score
- 0
- Country
This may be a stupid question but I want to put a 90 degree bend from the end of the exsisting radiator fittings so that I can fit a towel rail which is fed from the bottom.
The exsisting valves have a small thread. Will I be able to simply buy a 90 degree compression joint? If so how would I then attached to the radiator, I was told that you get "tails! that connect the valve to the radiator??????????
Cheers
Cheers
