Radiator For Twin Entry Valve (Microbore)
24 Nov 2006
Kent
I have a microbore central heating system which works very well. Each radiator is fitted with a twin entyr valve. I want to intoduce a door in one room which will mean that the none valve end of the radiator will overlap the doorway. Solution- fit a new radiator with the same connections as the existing radiator but which is about 200mm shorter. Problem - while I can reuse the existing valve (or by a new one -I have a source) I cannot source a radiator which will take a twin entry valve.
Can anyone help.
You may not find a new rad that takes twin entry, Better off altering the pipes
