Radiator help
29 Nov 2011
Glasgow
moving into new house and was decorating (radiators and hot water working) i bumped into a radiator and then noticed a leak on the pipe going in to the radiator (at the bit where you can choose what heat setting you want 1,2,3,4 etc) was quite a bit leak not just a drip the water was sort of flowing down the pipe anyway i turned the inlet pipe off and then to be safe the boiler off, took an hour to fix leak, but when i turned the boiler back on, it is giving hot water (sort off) but all the radiators are staying cold?? any ideas thanks
Go on, give us a bit more of a clue as to what boiler and system etc you have. There are only about 3000 + boilers to choose from.
Sorry not sure as not there at the moment, think its pretty old, got a guy coming to see it tomorrow, was just wondering if anyone had a general idea, i.e probably needs bled, or something inside the boiler itself. just strange that it worked great, then i turn it off and now its gone weird, apparently the hot water not working now either. but it "fires up" when you turn the tap on just the water comes out cool
