The radiator in the basement heats up even though it is turned off. It wasn't working before until I bled it and now the blasted thing wont turn off (makes me wish I didn't bleed it - we don't need heat in the basement, I only did it as i was trying to fix a different radiator!)
Anyway, I pulled the top off the radiator valve to make sure it was turned all the way off (in fact, it sounds like MORE water is coming to the radiator when it is all the way closed). This is that end of the radiator.
So I thought maybe if i closed the valve the OTHER end of the radiator, that should turn it off...however...at the other end is THIS!?! What the devil is this?
Any ideas how to turn this radiator off?
