Our radiator in hallway is leaking, it has a bulge in the radiator and small bit of water leaking from it. I have closed both valves on the radiator but problem is the room thermostat is in the hallway, do I need to set this lower now as hallway isn't going to warm up?
Also I noticed since I closed that radiator pressure on boiler is now going up to 2.5-3 (usually around 2 when hot) is this normal?
