Radiator is hot but does not heat up room??
2 Dec 2007
Hampshire
Help...
One of the radiator's in my son's room is hot and there is no cold parts on the radiator, but the room does not heat up. The room is fairly well insulated, can anyone give any suggestions?
Also are there different bleeding keys for older houses / radiators?
One of the radiator's in my son's room is hot .....
How many radiators has he got?
What is the size of the room? what is the size if the radiator? is it a double or single? what sort of window is installed?
Thanks for the quick reply
The room is 15' by 11' approx, only one radiator in the room. The window is sash window but has a double glazing infront of it.
You need to state how big the existing radiator is
width and height
also is it single or double panel
does it have "fins" on any of the panels
On VERY rare occasions i have found different air bleed screws to normal
You say fairly well insulated,does it have cavity wall insulation,insulation above etc
Does sound like rad too small,but need the dimensions to be sure :)
if it is a single, replace it with a double. don't forget the trv
if it is a flat panel rad with no fins on the back then change it for a newer one, convector radiators are much much better.
