Hi, there... Me again, the little newb at DIY D:
Again, sorry if what I'm asking is obvious but bear in mind we all start somewhere and that somewhere is knowing absolutely nothing
My problem is my radiator key won't turn in the valve.
I'm bleeding the upstairs radiators, and I've got two working so far, with only two more to go.
Now, the issue was it did work up until an extent; I put the key in went to turn and was having some trouble getting it turned.
There was a click as if I had opened it, and now the key won't turn at all- well, it's not so much it turning, it does turn but it's as if the valve has been corroded, so it doesn't open.
It's not the key, since it still turns on the other radiators, and I don't think its the valve, since it looks actually more square than the ones that did turn.
I've definitely got the key in right, and I'm definitely turning it in the right direction- what's up? o-o
