radiator - Lumpy metal protrusions and leaking valve
9 Feb 2006
Kent
Hi There
Have taken off a masterpeice of craftsmanship whilst decorating room. We have an old one piece (no fins) radiator that is approx 750mm high by 3m wide which has ben mechanically bent to fit a rounded bay window. When lightly sanding gloss paint off have noticed some lumpy protrusions in metal which look ominous. Are these the start of metal fatigue/potential leaks?. Also should the screw valves (which normally have the removable screw down caps on) leak when turned on/off?. These have stopped leaking now but when I turned the screw you did get water seaping up through the screw, is this normal? :evil:
computersaysno said:
...]Also should the screw valves (which normally have the removable screw down caps on) leak when turned on/off?. These have stopped leaking now but when I turned the screw you did get water seaping up through the screw, []is this normal?[/]
Yes it is normal. old ones get like that. You might consider fitting new valves while you are about it.
