radiator noise
8 May 2003
can anyone help we are having knocking noise when the rads are on any cure for this as its driving me nuts
CHRISSY. :?:
If you have TRV, turn down the opposite side rad valve to reduce the flow,then see what happen.
:oops: what does trv mean we dont have thermostats on rads,
as a matter of interst do the rad keys come in diff sizes because the one we have does not fit .
Chrissy
bossychic said:
what does trv mean ?
Thermostats Radiator Valve.
Shut down your return valve and open it a couple of turn to slow the flow rate.
Also check you have no air in radaitor,not sure about difference rads key size.
