Hi
We have one radiator in our house which will not heat at all. All others work fine, and are v hot at all points.
We called someone in under our service agreement and they suggest there may be a blockage somewhere in the piping between this and the next (hallway) radiator.
I'm not sure if this sounds correct. Facts so far:-
a. the in pipe is v hot, but the hear stops at the valve, i.e. no further not even the start of the radiator.
b. the radiator can be bleed - water comes out quite steadily. allowed it to bleed for quite a while, which eventually resulted in water starting to fill in the boiler's supply tank.
c. the out pipe is cold.
I think it seems more the problem is to do with the radiator itself, but then I'm not very technical re these things...
Anybody, with any ideas what might be up?
