Hey
Am planning to run a through Ethernet runs to different rooms around my flat.
Rather conveniently (I hope) the previous owner had boxing put along most of the rooms to hide radiator pipes / aerial cables etc - im hoping this will be the perfect place to do most of the Ethernet runs limiting the amount of wall I have to chase out.
Only concern is radiator pipes and the cables - obviously the pipes will be getting pretty hot, is there any sort of barrier product I can use to protect the Ethernet cables? Judging by the size of the boxing at the points where pipes are it might be fairly tight so the cables will be close.
Marc
Marc
