I often see Radiator pipes protrude through the floorboards and up into the valves, thus the pipes on show in front of the skirting.
However bathroom Towel Rails I have seen the pipes protrude from out the wall.
Is there a reason Radiators cannot be fitted the same as there is no skirting fitted yet.
Maybe too many bends restricting the flow?
Apart from aesphetics, i can then get all the Plumbing installed prior to the flooring and finally the skirtings.
As Plumbers Would you think its unreasonable to ask, obviously more time consuming, when i get the man round to quote.
Is there a Trade name for this type of install, I recall a bloke on telly naming the method years ago but forgot the name now.
Thanks in advance
Thanks in advance
