I've got a problem with just a couple of my radiators.
One half (the side where the feed comes in) gets hot as normal but the other side stays cold. I've bled them until the air stops but I never get the actual water coming out once the air stops.
I've read on DIYNOT that if the bottom is hot and the top is cold then it could be down to air but can't find anything about what could cause one side to get hot whilst the other remains cold.
Any ideas what could cause this?
If it could be sludge blocking it, is removing the radiator and flushing it out a relatively simple procedure or is it best left to a professional?
Thank you
Thank you
