radiator problem
4 Oct 2004
radiator luke warm at the top, cold at the bottom. The left hand side has a thermostat and the pipe leading to it gets hot. THe right hand side pipe is cold. It was working ok until I decided to bleed all my radiators. Some air did come out and then water and now it's just luke warm at the top and cold at the bottom. Darn, should have left it alone!!! Have tried turning off all the other rads and have checked that the pressure is ok. Can't get the thermostat off the radiator to check it and don't want to force it too much in case I do more damage. Has anyone got any ideas??????? Any help gratefully received!! :rolleyes: :D
_____________________________________
Moderator
split from hijacked post
