i have just fitted a new double radiator with the same pipes, replacing an old one..and i have a problem with only one panel getting warm.
I presume, with it being new, that its unlikely to be a blocked vent. I've also replaced a couple of radiators in different rooms at the same time.
Do you think this is likely to be a balancing problem? The back panel is hot , front panel is lukewarm but no pressure when I try to bleed front panel ?
