I've broken the pipes which come off the valves at both ends of the radiator, one has a bend in it so it has to be replaced, and the other is leaking from inside the valve, and i don't have a clue how to fix it as I have broke it and my dad is annoyed, any ideas????????
I think the pipe inside the valve is ok and the olive ring only has to be replaced, but the other side has a bend in it, so the pipe might need to be sawn off and replaced, can this be done with a compression joint??? and without soldering it?? any ideas will be welcome!!
Cheers
Cheers
