Recently moved into Victorian house that needs renovation. Trying to do stuff for myself as no money left and I want to do it anyway!
Wanted to remove radiator for decorating. I closed off both valves (1 may not be fully closed, but I think they are).
I should say this radiator has not got warm in any way since we’ve been here, all the other radiators work and we have an oil boiler.
Anyway back to removing radiator. I loosened nut as your supposed to, and started to drain the water. There was a bit of mucky water that came out but after about 1/2 large bucket it was running clear.
Then I realise the pipe that feeds the radiator is getting warm. I loosely tightened valve to stop the flow and on investigation found that the pipe coming under the floor boards is now warm as is the pipes leading to it from another room.
I went back & drained some more water in the hope I could do it. But then gave up as it’s lovely warm water.
I’ve righted nuts back up and left for plumber but maybe it’s simple?
Do you think the radiator could be connected to the hot water supply as it’s just like when you turn a trap on. I loosen the valve the water becomes hot. Tighten it back up and pipes go cold pretty quick.
I am waiting for a plumber but just wondered if anyone has ever experienced anything similar!
Many thanks
Many thanks
