Radiator removal
12 Apr 2016
Hi all
Just a quick question regarding the removal of a radiator.
I have a Combi boiler system and have removed a radiator in the bedroom for decorating. As there is still work to do over the next few weeks, what I was wondering is if it's possible to repressurize the boiler system (the pressure dropped as expected during removal which means no hot water currently) while this radiator is removed as it seems pointless to put the radiator back on only to have to remove it several more times while work is completed
Any help on the matter would be much appreciated
Yes thats fine. Make sure its isolated properly with the valves capped off.
Brilliant. Thanks Tay. Figured this should be one of those things not to take an educated gues at :)
