radiator removal
6 Sep 2005
Dorset
Hey guys,
i need to remove a radiator in the on-suite.
Thing is i have only ever taken rads off that are part of a combi system, its never been a problem as the rads have always had 2 shut off valves.
The house i am in now, has an ideal classic boiler system.
I can only see 1 valve on the rad.
What do i need to do to remove the rad????
thanks
thompy said:
Hey guys,
What do i need to do to remove the rad????Drain Down :cry: What`s on the other end :?: Has the 1 valve got 2 small pipes going into it :?:
thanks
you`re welcome ;)
At the side of the main knob You should see a little cap that you can unscrew... Under that you will see a slotted screw.. Turn it clockwise to close the return and turn the main knob to close feed.
I also have them on old system ripping them out at moment and fitting new rads and TRV's
Good Luck
Mick
cheers boys,
am i ok to run hte CH with the rad off and valves isolated?
Ta
Maick ??? Who the hell is that :confused:
Does your valve look like this
thought you said only one valve on rad ? So pipes do go into both ends then ?
Other side will be a lock shield with a cap on top
Which dirty minger owns that rad, not been cleaned since god were a lad!! :LOL: :LOL: :LOL:
:oops: Guilty as charged officer.. BUT i do have a small excuse, we are in the process of building an extension and the bathroom where that is doesnt have a floor at the moment..
Does that excuse me from the dirty looking vale gov ? Eh , does it eh, eh,
errr, NO.........could be a one pipe system :idea: THAT`s why I asked what`s on the other end.........old one pipers can have a M.Iron/copper no valve ;) .....no flies on me...just the marks where they`ve been :rolleyes:
Going off the subject a bit where can i get these valves from{in the UK} i have a rad that needs one replaceing .Does the one in the pic use smaller bore pipe?
Thanks Mark
Yes uses 10mm micro bore pipe.... You can have these when i take them off if you want... In fact, i threw 3 away last week :( Sorry
Mick
PS, Sorry Nige F, didnt realise it was YOU asking under a different user name.
