Sling it>>>>>>>>>>>>>>>>>if repaired either by welding or compounds when it bursts around the repair (and it will) you may not be in the property to notice it! So then it could be a new rad, new carpet, new flo0r etc. etc.
once the system is drained it would be a good idea to check all the other rads:
1. good practice
2. you might make some more cash
3. Saves the customer more $ in the long run
