Hello all,
I have a radiator in the house that is hot at the top and cold at bottom. Seems most likely cause is sludge or dirt in the radiator so i've taken the radiator off and hosed it through which a lot of dirt came out.
I've put it back on but still i have the same issue, is it likely the radiator is at fault and a replacement is needed or is there anything else i can try?
Thanks in advance
Kevin
Thanks in advance
Kevin
