I am working from home at the top of the house in a converted attic.
As this is the top of the house, I usually bleed the radiator quite often due to air pockets which is fine and the Radiator gets hot.
This is a new radiator, but it seems suddenly every 30 mins or so while the heating is on, the radiator bangs and crashes for 20 seconds, with water flooding and swooshing sounds? quite loud too?
There are no leaks or anything for concern, but is there a reason why this started, and whats causing it? its quite loud in the room when it does this, every 20-30 mins or so as if its filling up violently?
Any thoughts or help?
Thank you.
Thank you.
