Radiator size/rating/supplier advice please.
16 Aug 2012
Cheshire
I need to fit a new radiator into a well insulated conservatory which is 5m x 5m overall size.
The max size of the radiator could be 70cm H x 220cm W.
I need a good quality standard white finish radiator (not a ‘designer’ type) and would prefer a larger single panel rather than double panel type; ......however, would a single panel be adequate given the size of the conservatory?
Anyone recommend a good quality radiator and supplier please?
........I’m not looking for a ‘budget’ radiator ; cost is not an issue as it’s just a one-off so I don’t mind paying a bit extra for a decent product.
Thanks in advance for any replies.
To size up the rad correctly, you need to do heat loss calcs, including air change rates.
But when you come to the correct output required, there is nothing wrong with the Kudox heating panels.
