In the process of a CH overhaul including new Rads throughout the house.
My GF's builder of a dad is helping us along and we were told to use one of the many BTU calculators to work out the rad sizes needed and to then get the ones we wanted making sure we get one bigger than the BTU recommendations.
We checked on a couple of calculator websites just to check the numbers we were getting and duly ordered the new rads to be fitted.
And example would be Bedroom. 3.4m x 2.9m x 2.5m(height). insulated cavity, 300m insulation in loft, 1 outside wall, 2m2 or UPVC double glazing.
Online calculators have that at around 1400BTU or 400W.
Thats a 600 x 400 Type 11. Pretty much half what we took out!
To say they are a bit small is an understatement!
When they'd been fitted he came round the house as couldn't believe how small they were.
He's done his own calculations and agrees with us that our numbers are basically right but its hard to get over the fact that we have taken out rads that are 600x800-1000 and replaced them with 600 x 500's. I understand that technology moves on and efficiencies of them has probably increased since the 60's when the old ones were installed but even so! It's hard to see past the fact that the old pipes are sticking out the floors a foot away either side of the old rad!
Insulation in the property has been increased so it has had cavities done and 300mm in the loft plus Double glazing.
I'm thinking that realistically if they are undersized compared to what they should be then we're just going to have to get used to a slow warm up over instant heat and shut doors.
