- Joined
- 3 Oct 2012
- Messages
- 42
- Reaction score
- 0
- Country
Good afternoon,
I have a bay window curved radiator. Last winter the bottom third stopped getting hot. I have presumed this is due to a build up of sludge.
I took the radiator off the wall and flushed it through in the garden with a standard hose. A bit of sludge came out but not much. The water running through it came out clear. I sanded it ready for repainting. After putting the hose back on for a final check a lot more sludge has started to come out. I presume the sanding has dislodged it.
So my question is what can I put in the radiator to help dislodge the sludge? Do I have to use some type of fernox type product or can I put something else in (white vinegar, or citric acid etc). I have already biven it a tap with a rubber mallet. Any advice would be welcome.
For info, I do have a magnaclean filter fitted. And I will be topping up the inhibitor when the radiator goes back on.
