Advice needed before I take this thing apart. Is the fitting for tails standard or is it common for new valve tails not to be able to fit into a radiator?
My new TRVs come with 15 mm tails and the existing ones are I think 3/4". Whatever they are they're bigger than 15mm.
Also the existing tails don't appear to have that hex key shape on the inside to allow you to take them out. Thoughts and observations welcome.
2nd question:
I've read that you can undo a valve on a sealed central heating system and provided no other parts of the system are open the vacuum will prevent too much leakage.
If its a pressurised combi type how much pressure do you need to let off beforehand? All of it or a bit? [our system is normally about 1 bar or just over]
Thanks in advance
Marko[/i]
2nd question:
Thanks in advance
Marko[/i]
