I've recently had a bedroom completely dry-lined as the old lath and plaster was in a bad way. This involved fixing new plasterboard over the top and screwed to the studs. Now that I want to re-hang the radiator, I have realised the valves are too close to the wall as it is now some 12-15mm thicker. One valve/pipe has enough play but the other one is too rigid. Is it possible to get slimmer brackets for the radiator or will I have to chase them into the wall?
Cheers
Cheers
