My husband put some air in the pressure tank because water was overflowing in the overflow pipe. I later found that the overflow pipe is shared by the central heating and the main water tank. To establish where the water was coming I channeled two sources separately and left it for couple of days. Found that the main water tank is overflowing at certain times.
Now when I turn the heating on the top part of radiators become hot and the bottom stay cold or just slightly warm.
I can't seem to bleed the radiators as the bleeding bit is on the side of the radiator (the part against the wall) and the key is very small too.
what can I do? Please help me. Temperature is set at 20c
