radiator valve drain off
15 Jan 2010
Glasgow
Hi, i have no drain off on any of the radiators downstairs,so would like to fit a valve with drain off, but don't know which of the 4 radiators to fit it to, can i fit it to anyone of them
i have a combination boiler upstairs with 8mm microbore pipe coming from manifold's going to radiators
You need to fit it to the lowest point on the system, or all the lowest points on the system.
As already stated ideally they could all do with them on. You can also get ones that allow the radiator to be drained on its own.
thanks paul , as all the downstairs radiators are about the same distance from the floor give or take a inch or so , will I have to fit a drain off to every radiator downstairs
you will have drops to every rad downstairs so if you only fit one then it will only drain that rad & the ones upstairs leaving the other 3 rads & their pipework downstairs still full, change all the locksheild rad valves downstairs for ones with built in drain offs
I was wondering as the ground floor of my house is 16 inch above ground level, if I only fitted 1 drain off with hose attached going outside down the steps to ground level , would that 16" be enough to completely drain the system
to save me fitting drain valves to all downstairs radiators
from this reply even as I said I can drop a drain hose 16" it looks to me that the other 3 radiators will still be full of water, so looks like I will follow
advice & fit built in drain offs to all radiators downstairs
thanks to all for your help
It depends on if your downstairs radiators have pipe drops from the ceilings or are on a downstairs curcuit.
If on single pipe drops, each rad/curcuit needs drain offs to drain that curcuit.
If on a downstairs curcuit, normally you only need one drain of at the lowest point and that doesn't need to be on or near a rad, although easier to find for future owners/plumbers.
