I'm fitting a chunky tubular radiator that has a 15mm reducer fitted for the valves to screw into. When I screwed the valves in I realised there was nothing for the valves to butt up to and they would keep going in until the valve body started to foul the edge of the radiator.
On other radiators you can tighten the valve until it will obviously not turn any more but that's not the case here.
Has anyone experienced this before, and if so, how far do you screw the valve in and do you just have to use lots of PTFE to stop it leaking?
Thanks for your help.
