Hello,
Have had new rads fitted for a few months. Earlier today the hallway radiator valve started leaking from the body of the valve. The valves are palermo from screwfix. There must be a seal at the body joint. Can the valve body be tightened up or is it a faulty valve? Also if I turn off the valve on the other side of the rad can I still use the CH?
