Radiator valve
15 Mar 2004
Leicestershire
can a radiator valve let in air and lose pressure on a combi boiler or will it have to leak water
You need to lose water to lose pressure
We are loosing pressure when the radiator in the kitchen is on but when completely closed it’s perfect so the radiator has been replaced and we still have the same problem
Hopefully the radiator valves were exchanged for quality items and the expansion vessel pressure checked whilst drained down,it takes a few extra minutes but worth the effort :cautious:
The valves weren’t changed
The expansion vessel was checked
Can I check the radiator valves I can’t visually see a leak
