I noticed that about three weeks ago the radiators were not getting hot, and so the house was a bit cool. If I left the Honeywell boiler timer control set to constant then the house would eventually warm up. (The timer is working OK). The boiler is a Potterton Suprima circa 1997 and is firing up fine, but only for short periods. Currently set at about 3/4 of maximum heat output. Radiators do not appear to need bleeding and the water is nice and clean looking. Radiators are circa 1974 and do not have individual thermostats. Thermostat is Honeywell circa 1997. System has never been flushed, all radiators heat up fine, apart from one which needs re-balancing, but I can live with a temperate bedroom Hot water for showers etc is fine. Water tanks in loft both look fine.
So moving on the pump, a Grunfos UPS15-50x18 Mk11 probably 1974. If I switch the pump off, remove the central bolt, insert a screwdriver into the pump and rotate the pump anti-clockwise as per the arrows on the pump, refit, switch on, then the radiators heat up quickly.
So is this likely to be some form of solid/sediment interfering with the pump, do I need a new pump, or something else.
Thank you
Thank you
