Hi guys,
Wonder if you'd be able to give me some advice. I've just had two small radiators fitted in an extension. All other radiators get very hot, but these didn't warm up. I then closed a couple of the other radiators and heat transferred into the new ones. They get hot at the top but only warn at the bottom, why is this? I've bled them and the existing system is not actually that old, so I don't suspect it needs flushing.
The installer said he will come back and balance the radiators in the hope that this will rectify the problem in getting warmth to all the radiators, does this sound right?
He said he wasn't sure as to why the radiator wasn't fully heated, but that he'd investigate. Can any of you suggest what may be the problem?
Thanks in advance
Mario
Thanks in advance
Mario
