Hi guys need help to cut a long story short, our house is running a 1 pipe feed system where all radiators are fed off a 22mm pipe, now until i switched all rads off for the summer (TRV's) they where working fine, now weather is cold turned all rads back on and out of 7 rads only 2 are working properly!!!
one of the non working has hot water to the trv, but the rad is not getting hot, and before you ask it has been bled, but seems to keep getting air in, now most the other rads none of the pipes are even hot either side of the radiator, its baffling me because i am usaully on top of my system and can fix most things myself, i have bled the pump that pumps the water around the rads, have bled all the rads in turn starting furthest from boiler but still no avail.
Last week i had to replace my hot water cylinder after a burst fitting, and it emptied the f&e tank when it burst, could refilling this have caused a blockage in my pipe feed to rads?????.
There is definitely hot water getting around the system because the other end of the house runs off another pump, and all those rads get hot. (live in a bungalow)
any suggestions of help would be handy its doing my nut in!!!!!!!
