Hi guys
Ideal system boiler> When hot water only is selected a few of the rads have started getting hot and not much hot water when used. Im going to guess this is down to the three port valve? Yay? Nay?
If so would you recommend changing the motor and the valve or just the one?
Also would you say this problem could also be the cause of the boiler display showing random displays such as c-.-c-h- ETC?
Thanks in advance for your advice.
