Hi
I had a brand new central heating system installed on 26th Sep, with a ferrolli combi boiler.It was a fresh system as i hadn't got any heating in there previous and is only a 2bed house with 5 Rads. It cost £2200 in total, but on the 2nd day of using our system, we noticed that our living room rad had gone cold after an hour of use, i rang the fitter who came out and tried bleeding and balancing etc.... Yet it still goes cold,at the bottom and works its way up. After having them back about 15times to this problem, we finally got it to work without the trv on, they are drayton(make) i think. and wen the pin underneath was pressed it came back on.. They changed the valve as they thought it was that, but still goes off after approx 1hour whenever the trvs are on. I now have no trvs on any rads as its the only way i can get them all to work and keep hot..
They have been out again today and said that because we are having the boiler at max temp, 90deg, the trvs are cutting off as they trvs will only let the rad go to a certain heat . IS THIS RIGHT ???? i dont know anyone else that has had this problem, and their rads are always hot and stay hot....
PLEASE HELP!!!!!
PLEASE HELP!!!!!
