Help! Things are getting more complicated here!
Basically, here's a rundown of what's been happening:
1. It's a Honeywell system Y Plan, fifteen years old.
2. Developed a problem where heating wouldn't come on. Could only get it to switch on when boiler was on to heat water - then it switches off when water is hot.
3.Tried fitting a new synchron motor. No difference!
4. Tested microswitch and found the switch for the heating is working, but valve somehow isnt' switching it on.
5. Put in a tiewrap as a wedge to put pressure on CH microswitch when valve moves, and heating now comes on. Nice warm house!
6. Big problem! Water also heats up when heating is on - even when the water is turned off at the timer. Also, even though the tank stat is only set at 60, it's getting very very hot!
We've checked for loose wobbly bits in the motorised valve - screws for microswitch were loose and now tightened. Otherwise, what would cause the valve to not move around enough? And why would water and CH get mixed up?
