- Joined
- 25 Oct 2024
- Messages
- 2
- Reaction score
- 0
- Country
A couple of months ago our Worcester Bosch boiler had a leak on the right hand side. We had the right hand block changed.
After this was done, we noticed that our radiators were heating up any time we ran the hot water. Plumber came back out and checked the diverter valve was working, which it was. Then said a new plate heat exchanger should fix the issue.
Had the plate heat exchanger fitted this week, but the issue is still ongoing.
They came back out today to fit a new diverter valve just in case that was the issue, but found that it made no difference.
They've then said it may be a block on the left hand side, so have replaced the pipe there. Just used the hot tap tonight and the radiators are still firing up.
We've currently paid £500 to fix this issue that wasn't there before their original visit, and no one can work out what the issue actually is.
I guess my questions are - any ideas on what could be causing this if not the diverter/plate exchanger/blockage on the right? And where do I go with continuing to pay for all the new parts and fitting as it's at the point of putting us in hardship!
