Chaps
Can anyone assist as it is driving me mad. Over the summer despite having the theromostat low the radiators have been getting hot when I only want to heat the water!
I suspect the British Gas MV22M three-way value has something to do with it and is either knackered or the toggle switch is broken or in the wrong position. However with no markings for what the switch does in each position I am at a loss.
How can I test the valve or looking from above at the top of the valve with the switch on the top side what position is left and right supposed to be?
If the three-way valve is knackered can it be replaced without draining the system?
Heating system is the 'standard' set up with gundfus pump, lagged cylinder and header tank in the loft
