What fixings are best to use to hang a radiator on a plasterboarded stud partition wall? The P/B is 12.5mm & skimmed, the radiator is single and 1000mm x 600mm.
Thats my weapon of choice.
http://www.screwfix.com/prods/12229...all-Anchor-5-x-52mm-8-16mm-Pack-of-10[/QUOTE]
Mine too
I prefer these:
http://www.screwfix.com/prods/31268...-Toggle-M5-x-80mm-Drill-14-Pack-of-20[/QUOTE]
Trouble with them is that if you need to remove them the toggle drops in - I have used the ones above myself for my radiators with no problems. The good thing is that even if you are limited in space (we have a pocket door in the wall), you tighten it up and then you can remove the bolt and shorten them..
Just my two penneth worth
Cheers
Steve
i'm with cowboy, just got to think of the toggles as disposable.
i can never get the other ones to expand properly. and the little hooks the bite into the board just tear it apart...
maybe i am just using rubbish ones..
However saying all that the sheet of ply screwed to the studs, has to be the best job... but a lot more expensive than a couple of toggles.
