Hi guys
Two radiators on first floor keep needing bleeding.
I have a pumped system which used to work fine. In August I had the back boiler removed (so I could have an open fire) and new Potterton fitted. Pipework remained the same except for last metre to new boiler.
At the same time one under-specced radiator was replaced with a new double panel one and a TRV fitted. This rad works fine though I did find a wet patch on the carpet this morning. It seems there's a small leak out of the joint for the TRV. Zone valve packed up with new boiler so that was replaced too.
Have checked all the other rads - none leaking, all heating up fine.
The boiler overspill tank has 4" water in it, ball valve working, system feed outlet (or whatever you call it) seems not to be blocked (stuck my finger down it).
Any idea what's causing the air in the rads? I bleed them and then about a week later they need bleeding again.
Thank you!
Thank you!
